Content is not valid Base64
The GitHub node returned the error:
Your request is invalid or could not be processed by the service
Previously, the problem was that the node in the file could not be the same, so I used the ID for each file to avoid conflict, but even using this strategy, the error returned.
  • **n8n version:1.116.2
  • **Database (default: SQLite):Postgres
  • **n8n EXECUTIONS_PROCESS setting (default: own, main):main
  • **Running n8n via (Docker, npm, n8n cloud, desktop app):Docker
  • **Operating system:Linux
n8n handles binary files in a rather unusual way, and there are a few things you need to watch out for. Could you send a screenshot of the entire workflow and indicate which node you are trying to interact with the binary file?
A few things to keep in mind: if a node receives multiple inputs and one of them is a binary file, it will not be able to read it. If you need to merge a binary file with other data, you have to use a Merge node and select Append mode.
For example, in this workflow the On Form Submission node contains the binary data. I cannot pass the binary information through all the other nodes. Instead, I connect it directly to the node that needs to read it. Because I also need an ID, I merge them right before the node that is supposed to receive the binary file.
It worked now, but sometimes it gives an error. I can’t understand it, I didn’t change anything.
