I would like to add a flow after a “Split in Batches” function has executed all batches, e.g. for nested batches and other scenarios.
How is this possible? I have no idea where to connect the subsequent flow.
Thanks and best,
jo
Thanks and best,
jo
You can find an example here:
Look at the IF-Node “IF no more batches” with its expression:
{{$node["SplitInBatches"].context["noItemsLeft"]}}
thanks alot!
You are welcome. Have fun!
We’ve also added that to the FAQs in the node docs for future reference Split In Batches | Docs
redirect to a 404 not found,
this one works better: Split In Batches node noItemsLeft example | n8n workflow template
