Continue on fail not working?
Hi,
I have a flow getting infos from a Spreadsheet, sending some messages to telegram then updating the spreadsheet to mark that the messages has been sent.
I did activate “Continue on Fail” on the Telegram action but it didn’t continue to the end of the list. Basically it send messages only to the top of the list but not the end.
I received this error:
[403]: Forbidden: bot was blocked by the user
And I wanted to skip the users that blocks the bot.
How can I do it?
Are you using the latest n8n version?
No I am using the version 0.108.0. Should I upgrade?
Yes, please upgrade. That should fix this issue.
After updating it worked. Thanks a lot!
Glad to hear. Have fun!
