Conversational Chat using Slack Best Practices
I’ve been exploring the best approach for integrating a Slack bot with an N8N agent, specifically to handle multi-turn (back-and-forth) conversations. And I have to turn to the community because I am stumped.
Current Situation:
  • Basic integration—sending standard input from Slack to the agent and outputting a response—is straightforward.
  • Permissions and Slack scopes are correctly set.
  • I’m successfully receiving events from Slack and can send messages back.
Goal:
  • Emulate the interactive N8N chat experience directly within Slack, allowing seamless conversations without requiring users to repeatedly invoke or explicitly mention the bot each time.
Questions for those who’ve successfully implemented a Slack bot with N8N (or similar setups):
  1. Managing Conversation State:
  • Do you use Slack’s message timestamp (ts) as a unique identifier or key for maintaining conversation memory/state?
  • Is N8N’s standard memory sufficient for short conversations, or have you found the need for additional or external storage methods?
  1. Threading and Continuity:
  • How do you reliably loop the conversation back into the same Slack thread, maintaining context and state across multiple messages?
  • What’s the best approach to ensure users can seamlessly continue interacting without repeatedly referencing the bot explicitly?
  1. Triggers and Conversation Management:
  • What specific Slack events or commands do you rely on most effectively (e.g., @mentions, messages in specific channels, slash commands)?
  • I currently have access to both Bot Auth and User Auth scopes—are there any best practices or recommended ways to leverage these permissions for initiating or maintaining ongoing conversations?
I’m open to any insights, experiences, or best practices you can share regarding your own implementations.
Thanks in advance for your help!
Looking for an answer to the same :pray:
