Hi, I need to convert an audio file produced with the ElevenLabs API in MP3 format into another audio format using the CloudConvert API, but I’m having trouble uploading the file to CloudConvert. Can anyone help me?
I dont know cloudconvert. Please post the api reply from Cloudconvert node. it’s a data response?
PS. There is a community node built by cloudconvert: GitHub - cloudconvert/n8n-nodes-cloudconvert
PS2. remove your bearer authentication token from the post
