Copy-paste between workflows not working - "Paste" option missing from right-click menu
I used to be able to copy nodes from one workflow and paste them into another workflow by right-clicking on the canvas and selecting “Paste”. However, this functionality suddenly stopped working.
When I copy nodes from Workflow A (Ctrl+C), I see the “Copied to clipboard” toast notification. But when I switch to Workflow B and right-click on the canvas, the “Paste” option is completely missing from the context menu. Ctrl+V also does nothing.
This was working fine before, and I rely heavily on this feature to reuse nodes across workflows.
No error message. The UI shows “Copied to clipboard” on copy, but paste simply doesn’t work - neither via right-click menu (missing Paste option) nor keyboard shortcut.
What I’ve tried
  • Refreshed the browser page
  • Cleared browser cache
  • Tried different browsers (Chrome, Edge)
  • Tried Ctrl+V instead of right-click menu
  • Verified the nodes are actually selected before copying
Copy-paste between workflows broken in 2.12.3 (Docker) - HTTP internal IP access causing CORS/clipboard issues After upgrading to n8n 2.12.3 (Docker), I can no longer copy nodes from one workflow and paste them into another. The “Paste” option is missing from the right-click context menu, and Ctrl+V does nothing.
Browser console errors:
Access to XMLHttpRequest at 'https://abc.abc.com/rest/telemetry/proxy/v1/track'
from origin 'http://192.168.1.50:5678'
has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header
My environment:
  • n8n version: 2.12.3
  • Deployment: Docker (self-hosted)
  • Access URL: http://192.168.1.50:5678 (internal IP, no HTTPS, no domain)
  • Database: (PostgreSQL)
  • Browser: Edge
  • What I suspect:
    The clipboard functionality appears to be restricted when accessing n8n via HTTP + IP address instead of HTTPS + domain. The CORS errors suggest the browser is blocking clipboard operations due to security policies.
    What I’ve tried:
    • Refreshed browser, cleared cache
    • Tested Chrome and Edge
    • Verified nodes are selected before copying
    Questions:
    1. Is this a known limitation in 2.12.3 for HTTP/IP deployments?
    2. Are there any workarounds without setting up HTTPS/domain?
    3. Can I disable telemetry to reduce CORS errors (N8N_DIAGNOSTICS_ENABLED=false)?
    4. Is there a Docker env variable to enable “insecure” clipboard mode for internal use?
Yeah since youre accessing n8n over plain HTTP on a local IP the browser just blocks clipboard access entirely, it needs HTTPS to work. Easiest fix is the chrome flag chrome://flags/#unsafely-treat-insecure-origin-as-secure and add your n8n URL there.
