when setting Shopify Access Token API, it said Couldn’t connect with these settings
certificate has expired, what is wrong about this?
Looks like your Shopify API certificate has expired. You’ll need to generate a new API certificate from your Shopify admin panel and replace the old one in n8n’s Shopify node settings. Let me know if this works!
