Course 1 always returning same quiz results and not passing
I took course 1 more than 4 or 5 times and every time I received the same results (You scored 77% in the theory section and 44% in the workflow section. You need to score more than 80% in both the theory and workflow segments of the quiz.) even each time I changed my answers and I’m sure I did correctly.
Is there any issue in calculating the quiz results?
Thanks
Can you DM me the email address that you registered with so I can check the results?
DM sent. Thanks a lot.
Strange, I don’t see it anywhere. Can you forward me one or two of the course results emails so I have the exact timestamps?
Sure, I will forward as DM
Sounds good. A screenshot here will work too.
Edit: I meant in the DM.
I have attached the latest 2 screens also I have more if needed.
As a side note, I encountered issues with the Typeform quiz link when I tried to take the quiz, and happens randomly not sure if it is me or for other users, it would sometimes open after a delay.
I went through the scoring manually, and the result is as expected - you got a few answers wrong, sorry!
Thanks Bart for checking and confirming that the form is working, if it’s only the answers I can try again :slight_smile:
Same thing happened to me. Can you check the results
Hey same thing is happening with me I am getting same results for 3 time can you check what’s the problem please.
