Course level 2, workflow #1, vague isntructions, help please
I would liek some assistant, anyone can share his json please? tnx :slight_smile:
Hi @Eddy_Sraiber
Of course we should not be sharing our course work with eachother. That is cheating. :grin:
Could you tell us what is unclear. Maybe we can help.
This also allows the n8n team to improve it for others as well to make sure it is all clear for everyone.
on other parts of the course, you are sharing a full json for solution, yet, this is the 1st out of 3 parts, so having this part done incorectly, result in invalid data structure in airtable towards doing parts 2 and 3,
what is unclear to me, is the merge instructions, and how to add the region and subregion(if i dont udnerstand the table structure after merge, then i cannot figure what to fill on the other part with fillign region and subregion fields)
