Courses Level 2 - Error Handler - Discord Issue
Hi There,
My name is Thomas, I’m new here and enjoying folllowing the courses.
But Here I’m stuck.
I have created an Error Workflow, had no problem setting up a Gmail/Send message.
But it’s been hours that I am trying to set up a Discord node and failed after many many tries (most passed a JSON online checker).
The credentials I use are the same as per exercise 2 of Level 1 and it’s still working.
Here is my last try to set up the message expression value:
“message”: Warning: Workflow {{workflow.name}} error.\n\nAfter {{execution.retryOf}} executions in {{execution.mode}}, the node {{execution.lastNodeExecuted}} still crashes.\n\nHere are the error message and stack trace:\n{{ execution.error.message }}\n{{ execution.error.stack }}\n\nYour error handler.,
“channelId”: “{{964110271578791976}}”,
What’s wrong with me?
Please help.
Thomas
It looks like you’re using [[ ]] instead of {{ }} in your message which would be why the error is happening. Expressions in n8n are in double curly braces.
Thanks.
Problem solved.
Thomas
