I need help in creating a workflow that creates another workflow inside a project folder via another workflow. This can be easily done through the UI, but I was wondering if there is a way to do this through a workflow.
For context, I was able to create a workflow, but it was only placed inside the Personal folder of the project owner, not the project itself.
I was able to do a workaround, but it still does create the workflow in the Personal folder of the owner. I just then move the workflow to the project folder after.
Is there a way to create a workflow directly to a folder? Or is there a more elegant way to achieve this other than create then move?
Glad you managed to find a workaround. Unfortunately neither the n8n node nor the n8n public API support creating a workflow directly into a folder. We might however add support for this in the future.
