Create workflow to check Firewall for Compliance check and generate report and store it in SharePoint location
create workflow to check Firewall for Compliance check and generate report and store it in SharePoint location
Hey @ramji.cs hope all is well. Welcome to the community.
I think you might have confused this with Google Search :rofl:
Anyhow, is there a question there? Something doesn’t work? Something you need help with?
Hi Jabson,
i need support to create workflow for below given use case. this is my 1st workflow creation with zero n8n knowledge,
UseCase: n8n should login to Firewall and check the firewall config for Compliance check generate report in PDF and send the file to sharepoint location or email. can you help for creating workflow.
I see. Well, this is a community forum, you cannot really request anything here.
You could, however, share what you have tried already and what didn’t work.
