Credentials node changing property values
we have a custom credentials node that has username and password, logs into an app using http and returns a session id. The flow is webhook (basic auth) → get username/password → http node (using custom credential) → reponse in the credentials node, we use expressions for the username and password {{ $json.username }} and {{ $json.password }} . This all seems to work. Except then I made a mistake and called the webhook with and incorrect password and to my surprise, it still worked The credentials had replaced the expressions for username and password with fixed values from the execution. has anyone else seen this behaviour ? We just want the credentials node to keep the dynamic properties and not change them to fixed in the credentials node, the properties are defined as
            displayName: 'Username',
            type: 'string',
            required: true,
            default: ''
            displayName: 'Password',
            type: 'string',
            typeOptions: {
                password: true
            required: true,
            default: ''
the class “implements ICredentialType {” and in the preAuthentication hook we have this code
async preAuthentication(
        this: IHttpRequestHelper,
        credentials: ICredentialDataDecryptedObject
        let url = credentials['url'] as string;
        const username = credentials['username'] as string;
        const password = credentials['password'] as string;
the rest of the code simply calls the login url , and returns the sessionId the “authenticate” method is this
authenticate: IAuthenticateGeneric = {
        type: 'generic',
        properties: {
            headers: {
                Cookie: '={{"JSESSIONID=" + $credentials.jSessionId;}}'
so I cannot see anywhere how the credentials data is getting changed
FWIW. we’ve just tested the same flow with 1.84.1 and the problem does not occur. Switch to 1.77.1 and it re-occurs.
So this smells like a bug that has been fixed. If anyone has a ticket # or commit then it would be helpful to know.
This changelog seems to fit the bill
but the associated ticket only mentions oauth
  • core: Do not save credential overwrites data into the database (#13170) (298a7b0)
