Credentials not resolving and folders misaligned when promoting workflows from Dev → Prod
Hi all, looking for guidance on two recurring issues when we promote workflows from our Dev n8n to Prod:
  1. Credentials and environment variables not picked up in Prod
  • After importing a workflow from Dev to Prod, nodes often show missing credentials or resolve env vars to null until we manually intervene.
  • We do have the corresponding credentials and env variables configured in Prod (names/keys are the same), but the workflow still doesn’t bind automatically.
  • It looks like credential IDs differ between environments and the imported workflow may be referencing IDs from Dev.
  • Question: What’s the recommended way to promote workflows so credentials are matched by name/type (not ID), and env vars are resolved immediately without manual edits? Any best practices or tooling to strip credential IDs on export/import?
  1. Folders get misplaced in Prod
  • Some workflows land in the wrong folders (or root) after import to Prod, even though we didn’t change folder structure explicitly in the workflow export.
  • I suspect folder IDs differ between Dev and Prod, so the import falls back or creates duplicates.
  • Question: Is there a supported approach to map/migrate folder placement by folder name/path rather than folderId? Any recommended pipeline or API pattern to ensure the target folder exists and the workflow is moved there on import?
Environment and process
  • We export workflows from Dev and import into Prod (no shared DB).
  • Credentials and env vars exist in both environments (but IDs obviously differ).
  • We’d like a zero-manual-intervention promotion (CI-friendly) that:
  • Ensures required credentials exist in Prod (by name/type) and binds automatically
  • Resolves env vars immediately
  • Places workflows into the intended folder path reliably
What we’ve tried/considering
  • Stripping credential IDs from workflow JSON and leaving only name/type (so Prod can bind to the existing credential by name)
  • Using env vars in node parameters instead of credentials where possible
  • Pre-creating folders in Prod and mapping by name before import
  • A bootstrap script that upserts credentials/folders by name before importing workflows
Questions to the community
  • Is there an official or recommended way to:
  • Promote workflows with name-based credential mapping (not ID)?
  • Map folders by name/path during import (or move after import) using the API?
  • Validate that required credentials and env vars exist in Prod before import, and fail early if they don’t?
  • If you have a working Dev → Prod pipeline, could you share your steps or scripts (n8n API endpoints, CLI usage, do’s/don’ts)?
  • Any common pitfalls (e.g., OAuth tokens per environment, required restarts to load env changes) we should account for?
Thanks in advance!
There are a lot of questions.
First of all, which n8n version are you using? Paid Business / Enterprise or 2 independent free Community versions (one for Dev, the other for prod?)
enterprise
