Credentials not saving in a Node
I’m trying to add twilio creds to one of my workflows. The credentials are not being saved to the node.
Welcome to the N8n community @Shashank_Jha
Regarding your questions don’t type your password directly into the node
Instead, go to the "Credentials section on the left and create a saved password box for Twilio. Put your account details in there. Then, in your Twilio node, just select the name of that saved password box from a dropdown menu.
The node will grab the login details from the box you saved. This is the correct way to do it.
Hope this helps
