Custom HubSpot properties not appearing in n8n trigger node
Hi everyone,
I’ve created some custom properties in my HubSpot account, but I can’t see them in the n8n HubSpot trigger node, it only shows the default properties. I came across an old post mentioning that you could add or search for additional properties, but I can’t find that option in the current version of n8n.
Has anyone else run into this? Is there a way to access or display custom HubSpot properties in the n8n trigger node in the latest version?
Thanks for your help!
Same question here. Looks like “additional peroties” no longer exist in the latest version of n8n?
Found a workaround. I ended up using the HTTP Request node to call HubSpot REST API. Please let me know if there is a more elegant solution.
Just ran into the same problem and figured it out:
When you click on “add property” one of the dropdown items is called “Custom Properties”, click on it and from there a new dropdown menu appears with your custom properties.
Hope that helps!
