Custom node problem
Hi, I’m currently working on creating a custom node for n8n. I’ve successfully built the node, but when I check the n8n local instance on my website, I don’t see my custom node listed. Could you please help me troubleshoot this issue?
Hi @Ahmad_Hassam
What have you done to install the node on your n8n local instance?
Yes, it worked fine with my local n8n instance, but I am still facing the same error again.
You said your local instance was not working. I guess you mean self hosted.
So what did u do to install the custom node on that other instance?
No, you misunderstood. My whole system is working fine, but when I check the node on my local instance, it doesn’t show up
Sorry but you need to be clear on what you are doing and what the issue is. Like this we cannot help you.
You say it works fine then doesn’t then it does then it doesn’t
