Hi there, I recently updated my selfhosted n8n from 1.35 to 1.45 and now I have the problem that my advanced-flow-nodes are unknown to the sytem. All other community nodes like Ninox or sevDesk are well known
I’m not sure if the pushRef is related, but the relevant errors seem to be the last few lines.
ResponseError: The query parameter "pushRef" is missing!
at Push.handleRequest (/usr/local/lib/node_modules/n8n/dist/push/index.js:44:19)
at /usr/local/lib/node_modules/n8n/dist/push/index.js:109:70
at newFn (/usr/local/lib/node_modules/n8n/node_modules/express-async-errors/index.js:16:20)
at Layer.handle [as handle_request] (/usr/local/lib/node_modules/n8n/node_modules/express/lib/router/layer.js:95:5)
at trim_prefix (/usr/local/lib/node_modules/n8n/node_modules/express/lib/router/index.js:328:13)
at /usr/local/lib/node_modules/n8n/node_modules/express/lib/router/index.js:286:9
at Function.process_params (/usr/local/lib/node_modules/n8n/node_modules/express/lib/router/index.js:346:12)
at next (/usr/local/lib/node_modules/n8n/node_modules/express/lib/router/index.js:280:10)
at AuthService.authMiddleware (/usr/local/lib/node_modules/n8n/dist/auth/auth.service.js:60:13)
at processTicksAndRejections (node:internal/process/task_queues:95:5)
Failed to renew license: renewal failed because current cert is not initialized
UnrecognizedNodeTypeError: Unrecognized node type: Any".
UnrecognizedNodeTypeError: Unrecognized node type: FilterAdvanced".
UnrecognizedNodeTypeError: Unrecognized node type: For".
UnrecognizedNodeTypeError: Unrecognized node type: Generator".
UnrecognizedNodeTypeError: Unrecognized node type: IFAdvanced".
UnrecognizedNodeTypeError: Unrecognized node type: Logger".
UnrecognizedNodeTypeError: Unrecognized node type: Paging".
UnrecognizedNodeTypeError: Unrecognized node type: Push".
UnrecognizedNodeTypeError: Unrecognized node type: Pop".
UnrecognizedNodeTypeError: Unrecognized node type: Sizecheck".
Should not be relevant, just try to create any flow using these nodes: n8n-nodes-advanced-flow - npm (npmjs.com)
- n8n version: 1.45
- Database (default: SQLite): Postgres
- Operating system: Ubuntu
Further information:
- The nodes are installed and all dependencies are up to date
- Any flow including one of the nodes just shows a ? instead of the symbol
- in .n8n/nodes/node_modules there is a folder n8n-nodes-advanced-flow with the following structure:
4 drwxr-xr-x 3 node node 4096 Jun 16 20:22 .
4 drwxr-xr-x 25 node node 4096 Jun 16 20:22 ..
4 -rw-r--r-- 1 node node 1074 Jun 16 20:22 LICENSE.md
4 -rw-r--r-- 1 node node 2021 Jun 16 20:22 README.md
4 drwxr-xr-x 3 node node 4096 Jun 16 20:22 dist
0 -rw-r--r-- 1 node node 0 Jun 16 20:22 index.js
4 -rw-r--r-- 1 node node 2064 Jun 16 20:22 package.json
Dist:
4 drwxr-xr-x 3 node node 4096 Jun 16 20:22 ..
4 drwxr-xr-x 13 node node 4096 Jun 16 20:22 nodes
4 -rw-r--r-- 1 node node 2421 Jun 16 20:22 package.json
44 -rw-r--r-- 1 node node 42857 Jun 16 20:22 tsconfig.tsbuildinfo
nodes:
4 drwxr-xr-x 13 node node 4096 Jun 16 20:22 .
4 drwxr-xr-x 2 node node 4096 Jun 16 20:22 Any
4 drwxr-xr-x 2 node node 4096 Jun 16 20:22 CredentialReader
4 drwxr-xr-x 2 node node 4096 Jun 16 20:22 FilterAdvanced
4 drwxr-xr-x 2 node node 4096 Jun 16 20:22 For
4 drwxr-xr-x 2 node node 4096 Jun 16 20:22 Generator
4 drwxr-xr-x 2 node node 4096 Jun 16 20:22 IfAdvanced
4 drwxr-xr-x 2 node node 4096 Jun 16 20:22 Logger
4 drwxr-xr-x 2 node node 4096 Jun 16 20:22 Paging
4 drwxr-xr-x 2 node node 4096 Jun 16 20:22 ShelfPop
4 drwxr-xr-x 2 node node 4096 Jun 16 20:22 ShelfPush
4 drwxr-xr-x 2 node node 4096 Jun 16 20:22 Sizecheck
Any good idea where to start debugging this error?
