Hi to everyone
When i generate a workflow, i normally set up some HTTP Nodes to do requests to our server just like an api request. This type of HTTP Requests may require to be called many times in a single workflow, with various url for many reason. An example would be to first call the server to get a list of items, and then for each items, send a message.
So in this case, i set up an HTTP node to call our server to read the items, and another HTTP node to call our server to send those items. Both of nodes are HTTP nodes in this case, and they both have their own url to call, with specific parameter, header authorization, etc.
My question is: is there any way to differentiate between develop and production? So for example when i am generating a new workflow i need some data that is the same for every HTTP request (a user id, an authorization header, and so on)âŚ
At the moment i have found a âdirtyâ solution by adding to my workflow two SET nodes, one for develop environment variables, and one for production environment variables. Is there a better way to setup this difference between environments?
With this help, i would not have anymore need to change manually every HTTP request node by getting the âenvironment variablesâ from the SET dev node or SET prod node.
