Hi, What is the difference between using http node and qualys http node? I do not see any APIs of qualys pre built in the node.
Thanks Bringasher. I assumed that would be the case. But when I am evaluating using the n8n cloud trial, I don’t see the pre-filled nodes. Its just a placeholder node with name Qualys http and no API or field details. How can I view/check the capabilities of the pre-filled nodes? I did not find it in documentation as well.
