Difference between RiotTmpl and Tournament
Hi,
does anyone know if there’s documentation somewhere for the differences between RiotTmpl and Tournament? I’ve tried looking in n8n docs, on GitHub and here in the forums but haven’t found anything. Before I upgrade to 1.9.x I’d just like to know what (if anything) will break or need editing.
Thanks!
  • n8n version: 1.8.2
  • **Database (default: SQLite):SQLIte **
  • Running n8n via (Docker, npm, n8n cloud, desktop app):docker
Hey there! I’m the primary developer of Tournament. Tournament was designed to be backwards compatible with riot-tmpl so you shouldn’t need to do anything. We did quite extensive testing to make sure it wouldn’t require any changes for users but if you do find anything please let us know!
Hi Val,
Thanks, that’s great! Appreciate the quick response.
