Hey @Gregoire_Hamille,
No problem, I had some time off. I will have a play on my test instance and see if I can find something that works.
As a temporary solution you could use the below workflow which should do what you are after.
Hi @Jon
Thanks a million, that’s a smart dodge ![]()
