Problem Description
Hello, Community!
I’m trying to create a workflow to generate audio from text using Google’s Speech Generation API (Gemini TTS / Cloud Text-to-Speech) and save the audio locally. I’ve made a lot of progress, but I’m stuck at the stage of processing the audio returned by the API.
My goal: Get text, send it to Google’s TTS API, receive the audio (Base64) and save it as an .mp3 file locally.
Current workflow (summarized): Start → Read .txt → Extract Text → Code (Split Text into Snippets) → Loop → HTTP Request (Calls TTS API) → Convert to PCM File (HERE’S THE PROBLEM) → Read/Write Files (Saves .pcm) → Execute Command (FFmpeg to .mp3).
The Convert to PCM File node is failing with the error “Operation not permitted, make sure you have the correct permissions” or something like TypeError: Cannot read properties of undefined (reading ‘data’).
My observations and what I’ve tried:
- HTTP Request API:
o The API is receiving the request and does not return a 400/403 error when the text is sent verbatim.
o The URL being used is https://generativelanguage.googleapis.com/v1beta/models/gemini-2.5-flash-preview-tts:streamGenerateContent.
o Authentication is via X-Goog-Api-Key in the header. - The Convert to PCM File node:
o Expects binary data in a specific field (configured as candidates[0].content.parts[0].inlineData or variations like data).
o The “Operation not permitted” error suggests that the input data for conversion may be missing, invalid, or the node does not have permission to the temporary directory.
o I have already tried specifying the full output path (D:\Files\Script\Narration\out_put_excerpt_X.pcm) and checking permissions.
Error message
error_node_id: '5',
webhook_domain: null,
sharing_role: 'owner',
credential_type: null,
is_managed: false,
eval_rows_left: null,
instance_id: 'ace52b8e95ec3941fe529997779d46984877a3f656abdf3627f580bf7b404e6b',
version_cli: '1.100.1'
context: { ip: ‘0.0.0.0’ }
2025-07-08T13:06:55.304Z [Rudder] info: Your message must be < 32kb. This is currently surfaced as a warning. Please update your code {
userId: ‘ace52b8e95ec3941fe529997779d46984877a3f656abdf3627f580bf7b404e6b#cab74c88-5076-4258-96e3-4f4d65e0cf6f’,
event: ‘Workflow execution errored’,
properties: {
workflow_id: ‘ra3KvsJimF3asKYH’,
is_manual: true,
version_cli: ‘1.100.1’,
success: false,
user_id: ‘cab74c88-5076-4258-96e3-4f4d65e0cf6f’,
execution_mode: ‘manual’,
error_message: 'The value in “…”
… 1785290 more characters,
error_node_type: ‘n8n-nodes-base.convertToFile’,
node_graph: {
node_types: [Array],
node_connections: [Array],
nodes: [Object],
notes: {},
is_pinned: false
node_graph_string:
error_node_id: ‘5’,
instance_id: ‘ace52b8e95ec3941fe529997779d46984877a3f656abdf3627f580bf7b404e6b’
My workflow
NodeOperationError: The value in "8P/4/wIA///9/wIABwAGAPr/7//i/8//w/...
- n8n version: 1.100.1 (Self Hosted)
- Database (default: SQLite): I don’t use
- Running n8n: npm
- Operating system: Windows 10
