Do LinkedIn outreach using SourceGeek + n8n
Since the official LinkedIn node does not have any advanced features, we created and published a specific Node which lets you do advanced lead generation using all the nice LinkedIn features.
This allows you to:
  • Retrieve enriched LinkedIn profile information (hard & soft skills)
  • Import search results from LinkedIn straight into your workflow
  • Send out Invites (including a note)
  • Send out InMails to specific profiles
  • Send out long messages to your 1st degree network
:locked_with_key: Before You Begin — Subscribe to SourceGeek to generate a n8n key
Sign up to SourceGeek and generate a key. You can simple create an using and use all features for free. The platform offers you a free trial for the first 7 days
:backhand_index_pointing_right: Login | SourceGeek
After creating an account, go to the bottom left to Settings → Integrations to create a n8n key
:rocket: Install the SourceGeek node
Once having the key, go to your n8n worflow and search for the certified SourceGeek node. After filling in the credentials you can make use of all the features
:puzzle_piece: Workflow Ideas
  • Import all detailed profile info using a search
  • Enrich the data and generate custom invite messages
  • Send out scheduled invites and possible follow ups
:information_source: More info
For questions or detailed info, visit any of these pages
