I am following the instructions of this page to create a custom image of n8n:
Like suggested this is my dockerfile:
FROM docker.n8n.io/n8nio/n8n
RUN apk --update add curl
But the build does not complete.
=> ERROR [2/2] RUN apk --update add curl 0.3s
> [2/2] RUN apk --update add curl:
#0 0.206 ERROR: Unable to lock database: Permission denied
#0 0.207 ERROR: Failed to open apk database: Permission denied
Dockerfile:2
1 | FROM docker.n8n.io/n8nio/n8n
2 | >>> RUN apk --update add curl
ERROR: failed to solve: process "/bin/sh -c apk --update add curl" did not complete successfully: exit code: 99
For your info, I am trying to build an image for ARM processor, but I assume the image for both processors should behave the same.
