sgw
1
latest image f9d0a9e1924c
I try to run my workflow and it puts the container into high load.
# docker-compose logs -f
n8n-n8n-1 | The session "lm6npjtun8e" is not registered.
[ .. repeated ..]
Tried to disable some nodes in my workflow, restarted the stack, same result.
Tried with image n8nio/n8n:0.205.0
: same result.
Maybe something has crashed in my setup. Maybe it’s some kind of bug. I just want to report this.
Jon
2
Hey @sgw,
When you say high load what do you mean?
sgw
3
@Jon The docker host revs up, and 2 or so processes use >90 % CPU …
Jon
4
@sgw what is the workflow doing? How much data is it loading? Does it happen with smaller workflows? How is the workflow being triggered?
sgw
5
It’s triggered by a Start-Node, so manually.
Start triggers a Set-Node, which sets a ID to a specific value (it’s a test still).
The amount of data is small:
it calls an API and fetches a ticket from Zammad (not using the Zammad node, but via HTTP request).
That ticket consists of 4 articles and 3 attachments … all these should be fetched via API calls.
The list of attachments gets “Split out” into 4 parts, and piped into another HTTP-Request that fetches these files.
That branch of the workflow is the one shown here: Zammad and Webhook - #12 by MutedJam
sgw
6
Update, maybe solved:
I had non-connected nodes inside of the workflow, basically left over from copying together various workflows and fitting parts of them together.
I cleaned up the workflow now, saved, currently it runs through OK.
Sorry for the noise, it maybe is an FAQ to keep the canvas clean.
system
Closed
7
