Hi everyone ![]()
I’m running n8n on-premise with Docker Compose (PostgreSQL + Redis + queue mode + a dedicated worker container).
The main n8n instance correctly enqueues jobs, but no executions ever start — workflows remain stuck in the “Queued” state.
Both containers (n8n and n8n-worker) are up and connected to the same Redis and Postgres instances.
Redis is reachable (PONG), but the worker never picks up the jobs.
I suspect the worker is not correctly registered or not consuming from the queue.
There is no explicit error in the main n8n logs — it just says:
Enqueued execution 390 (job 280)
Enqueued execution 393 (job 283)
Enqueued execution 395 (job 285)
And in the worker logs, I either get:
2025-10-22T11:14:15.005Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:14:15.027Z | debug | Execution added {"executionId":"409","file":"active-executions.js","function":"add"}
2025-10-22T11:14:15.030Z | info | Enqueued execution 409 (job 299) {"scopes":["scaling"],"executionId":"409","jobId":"299","file":"scaling.service.js","function":"addJob"}
22T11:14:30.005Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:14:30.006Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:14:30.027Z | debug | Execution added {"executionId":"411","file":"active-executions.js","function":"add"}
2025-10-22T11:14:30.029Z | info | Enqueued execution 411 (job 301) {"scopes":["scaling"],"executionId":"411","jobId":"301","file":"scaling.service.js","function":"addJob"}
(node:7) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 global:completed listeners added to [Queue]. MaxListeners is 10. Use emitter.setMaxListeners() to increase limit
(Use `node --trace-warnings ...` to show where the warning was created)
(node:7) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 global:failed listeners added to [Queue]. MaxListeners is 10. Use emitter.setMaxListeners() to increase limit
2025-10-22T11:14:44.322Z | debug | Querying database for waiting executions {"scopes":["waiting-executions"],"file":"wait-tracker.js","function":"getWaitingExecutions"}
22T11:14:45.004Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:14:45.005Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:14:45.021Z | debug | Execution added {"executionId":"412","file":"active-executions.js","function":"add"}
2025-10-22T11:14:45.026Z | info | Enqueued execution 412 (job 302) {"scopes":["scaling"],"executionId":"412","jobId":"302","file":"scaling.service.js","function":"addJob"}
22T11:15:00.004Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:15:00.005Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:15:00.021Z | debug | Execution added {"executionId":"415","file":"active-executions.js","function":"add"}
2025-10-22T11:15:00.023Z | info | Enqueued execution 415 (job 304) {"scopes":["scaling"],"executionId":"415","jobId":"304","file":"scaling.service.js","function":"addJob"}
22T11:15:15.005Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:15:15.006Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:15:15.025Z | debug | Execution added {"executionId":"417","file":"active-executions.js","function":"add"}
2025-10-22T11:15:15.029Z | info | Enqueued execution 417 (job 307) {"scopes":["scaling"],"executionId":"417","jobId":"307","file":"scaling.service.js","function":"addJob"}
22T11:15:30.004Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:15:30.005Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:15:30.030Z | debug | Execution added {"executionId":"418","file":"active-executions.js","function":"add"}
2025-10-22T11:15:30.032Z | info | Enqueued execution 418 (job 309) {"scopes":["scaling"],"executionId":"418","jobId":"309","file":"scaling.service.js","function":"addJob"}
2025-10-22T11:15:44.322Z | debug | Querying database for waiting executions {"scopes":["waiting-executions"],"file":"wait-tracker.js","function":"getWaitingExecutions"}
22T11:15:45.004Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:15:45.005Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:15:45.018Z | debug | Execution added {"executionId":"421","file":"active-executions.js","function":"add"}
2025-10-22T11:15:45.021Z | info | Enqueued execution 421 (job 310) {"scopes":["scaling"],"executionId":"421","jobId":"310","file":"scaling.service.js","function":"addJob"}
22T11:16:00.002Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:16:00.003Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:16:00.018Z | debug | Execution added {"executionId":"422","file":"active-executions.js","function":"add"}
2025-10-22T11:16:00.021Z | info | Enqueued execution 422 (job 312) {"scopes":["scaling"],"executionId":"422","jobId":"312","file":"scaling.service.js","function":"addJob"}
22T11:16:15.003Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:16:15.003Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:16:15.024Z | debug | Execution added {"executionId":"424","file":"active-executions.js","function":"add"}
2025-10-22T11:16:15.026Z | info | Enqueued execution 424 (job 314) {"scopes":["scaling"],"executionId":"424","jobId":"314","file":"scaling.service.js","function":"addJob"}
22T11:16:30.004Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:16:30.005Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:16:30.029Z | debug | Execution added {"executionId":"427","file":"active-executions.js","function":"add"}
2025-10-22T11:16:30.031Z | info | Enqueued execution 427 (job 317) {"scopes":["scaling"],"executionId":"427","jobId":"317","file":"scaling.service.js","function":"addJob"}
2025-10-22T11:16:44.322Z | debug | Querying database for waiting executions {"scopes":["waiting-executions"],"file":"wait-tracker.js","function":"getWaitingExecutions"}
22T11:16:45.004Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:16:45.004Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:16:45.027Z | debug | Execution added {"executionId":"428","file":"active-executions.js","function":"add"}
2025-10-22T11:16:45.029Z | info | Enqueued execution 428 (job 318) {"scopes":["scaling"],"executionId":"428","jobId":"318","file":"scaling.service.js","function":"addJob"}
22T11:17:00.004Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:17:00.005Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:17:00.021Z | debug | Execution added {"executionId":"430","file":"active-executions.js","function":"add"}
2025-10-22T11:17:00.024Z | info | Enqueued execution 430 (job 320) {"scopes":["scaling"],"executionId":"430","jobId":"320","file":"scaling.service.js","function":"addJob"}
22T11:17:15.004Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:17:15.005Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:17:15.022Z | debug | Execution added {"executionId":"433","file":"active-executions.js","function":"add"}
2025-10-22T11:17:15.025Z | info | Enqueued execution 433 (job 323) {"scopes":["scaling"],"executionId":"433","jobId":"323","file":"scaling.service.js","function":"addJob"}
22T11:17:30.003Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:17:30.004Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:17:30.021Z | debug | Execution added {"executionId":"434","file":"active-executions.js","function":"add"}
2025-10-22T11:17:30.024Z | info | Enqueued execution 434 (job 324) {"scopes":["scaling"],"executionId":"434","jobId":"324","file":"scaling.service.js","function":"addJob"}
2025-10-22T11:17:44.322Z | debug | Querying database for waiting executions {"scopes":["waiting-executions"],"file":"wait-tracker.js","function":"getWaitingExecutions"}
22T11:17:45.004Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:17:45.005Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:17:45.018Z | debug | Execution added {"executionId":"436","file":"active-executions.js","function":"add"}
2025-10-22T11:17:45.021Z | info | Enqueued execution 436 (job 326) {"scopes":["scaling"],"executionId":"436","jobId":"326","file":"scaling.service.js","function":"addJob"}
22T11:18:00.003Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:18:00.004Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:18:00.024Z | debug | Execution added {"executionId":"439","file":"active-executions.js","function":"add"}
2025-10-22T11:18:00.028Z | info | Enqueued execution 439 (job 329) {"scopes":["scaling"],"executionId":"439","jobId":"329","file":"scaling.service.js","function":"addJob"}
22T11:18:15.006Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:18:15.007Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:18:15.029Z | debug | Execution added {"executionId":"441","file":"active-executions.js","function":"add"}
2025-10-22T11:18:15.032Z | info | Enqueued execution 441 (job 331) {"scopes":["scaling"],"executionId":"441","jobId":"331","file":"scaling.service.js","function":"addJob"}
22T11:18:30.003Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:18:30.004Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:18:30.016Z | debug | Execution added {"executionId":"442","file":"active-executions.js","function":"add"}
2025-10-22T11:18:30.017Z | info | Enqueued execution 442 (job 332) {"scopes":["scaling"],"executionId":"442","jobId":"332","file":"scaling.service.js","function":"addJob"}
2025-10-22T11:18:44.321Z | debug | Querying database for waiting executions {"scopes":["waiting-executions"],"file":"wait-tracker.js","function":"getWaitingExecutions"}
22T11:18:45.005Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:18:45.006Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:18:45.028Z | debug | Execution added {"executionId":"445","file":"active-executions.js","function":"add"}
2025-10-22T11:18:45.032Z | info | Enqueued execution 445 (job 335) {"scopes":["scaling"],"executionId":"445","jobId":"335","file":"scaling.service.js","function":"addJob"}
22T11:19:00.004Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:19:00.005Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:19:00.022Z | debug | Execution added {"executionId":"447","file":"active-executions.js","function":"add"}
2025-10-22T11:19:00.024Z | info | Enqueued execution 447 (job 337) {"scopes":["scaling"],"executionId":"447","jobId":"337","file":"scaling.service.js","function":"addJob"}
22T11:19:15.003Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:19:15.003Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:19:15.022Z | debug | Execution added {"executionId":"448","file":"active-executions.js","function":"add"}
2025-10-22T11:19:15.026Z | info | Enqueued execution 448 (job 338) {"scopes":["scaling"],"executionId":"448","jobId":"338","file":"scaling.service.js","function":"addJob"}
22T11:19:30.004Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:19:30.004Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:19:30.021Z | debug | Execution added {"executionId":"450","file":"active-executions.js","function":"add"}
2025-10-22T11:19:30.024Z | info | Enqueued execution 450 (job 340) {"scopes":["scaling"],"executionId":"450","jobId":"340","file":"scaling.service.js","function":"addJob"}
2025-10-22T11:19:44.322Z | debug | Querying database for waiting executions {"scopes":["waiting-executions"],"file":"wait-tracker.js","function":"getWaitingExecutions"}
22T11:19:45.003Z | debug | Executing cron for workflow {"scopes":["cron"],"workflowId":"LnmWyfFhEgfbk31d","nodeId":"4a0288e4-df57-4af8-a374-62f9994acdc9","cron":"*/15 * * * * *","instanceRole":"leader","file":"scheduled-task-manager.js"}
2025-10-22T11:19:45.004Z | debug | Received trigger for workflow "My workflow 2" {"scopes":["workflow-activation"],"file":"active-workflow-manager.js","function":"emit"}
2025-10-22T11:19:45.027Z | debug | Execution added {"executionId":"452","file":"active-executions.js","function":"add"}
2025-10-22T11:19:45.030Z | info | Enqueued execution 452 (job 343) {"scopes":["scaling"],"executionId":"452","jobId":"343","file":"scaling.service.js","function":"addJob"}
or nothing — it just idles and never processes jobs.
It runs every 15 seconds — each time it triggers, the job goes to “Queued” but never executes.
No output, since the job never starts.
- n8n version: 1.116.2
- Database: PostgreSQL
- n8n EXECUTIONS_PROCESS setting:
queue - Running n8n via: Docker Compose (on-premise)
- Operating system: Ubuntu Server
Docker Compose excerpt
n8n:
image: n8nio/n8n:latest
environment:
- DB_TYPE=postgresdb
- DB_POSTGRESDB_HOST=db
- DB_POSTGRESDB_USER=postgres
- DB_POSTGRESDB_PASSWORD=${POSTGRES_PASSWORD}
- DB_POSTGRESDB_DATABASE=postgres
- EXECUTIONS_MODE=queue
- QUEUE_BULL_REDIS_HOST=redis
- QUEUE_BULL_REDIS_PORT=6379
- N8N_RUNNERS_ENABLED=true
- OFFLOAD_MANUAL_EXECUTIONS_TO_WORKERS=true
volumes:
- n8n_storage:/home/node/.n8n
n8n-worker:
command: n8n worker --concurrency=5
environment:
depends_on:
- redis
- n8n
Would appreciate any guidance to identify why the worker does not process queued jobs ![]()
Thanks in advance!
