Does a custom JSON Schema validation node qualify for community node verification, or does it count as a "Logic/Flow control" node?
Hi everyone,
We’re considering building and submitting a custom community node that validates incoming JSON against a JSON Schema (success/error branch output). The verification guidelines mention “Logic or Flow control nodes” aren’t being accepted at the moment. Would a data-validation node like this fall under that exclusion, or would it be considered eligible since it doesn’t duplicate a core n8n node 1-for-1?
Thanks!
Hi @Niel-Stroobants, not duplicating a core node is only one requirement. The guidelines also say each package should integrate one third-party service. If this only validates JSON locally, it doesn’t fit that description.
They don’t explicitly classify schema validators as Logic/Flow control, so I’d email nodes@n8n.io with the proposed validation and success/error outputs before building it for verification.
