So I have very big database, and very much properties inside of it. I calculated that I can manually build 15 properties, after top of it I need to type it.
Please share the workflow (without credentials can’t show it)
That one is interesting, So a 414 means a URI is too long so I wonder if we are doing something odd. I will make a new database with a bunch of properties and see if I can reproduce it.
Alright, It took me 18 properties to get there but I have now hit an error. I don’t have the same one but it looks like we could be doing something the notion API doesn’t like I will need to give it a run in my dev environment to properly dig into it.
I have made a note to do that either later today or in the morning.
Hey @Jon , thank you for responding! I think the solution is avoid large databases and separate it into complicated several databases with relations. So in my database I have something for user (names, ages, salary, etc) and automation things (ids, db ids, automated email addresses etc), and I will just create 2 databases and connect them by relations, it will decrease my post payloads for notion
