Drag with Ctrl/Shift to auto-reference the node by name instead of typing $('Node Name')
The idea is:
Allow holding Ctrl or Shift while dragging a variable (e.g., from Google Sheets) to auto-insert the full node reference by name, like:
{{ $('Google Sheets').item.json.row_number }}
instead of the default shorter form:
{{ $json.row_number }}
My use case:
In more complex workflows, $json.row_number can be unclear—especially when multiple nodes have similar structures or outputs. I often rename my nodes for clarity, and would prefer that variable insertions reflect those names automatically.
Having to manually type $('Google Sheets').item.json.row_number each time is tedious. It would be much smoother if holding Ctrl or Shift while dragging a variable inserted the full reference with the node name.
  • Improves clarity in workflows with multiple similar nodes
  • Makes debugging and collaboration easier
  • Speeds up editing by reducing manual typing
  • Gives power users more control without changing default behavior
Reddit discussion for context: Best way to force n8n to use the full node name
Yes—happy to test or provide feedback!
This will help a lot. I always have to put a node between one and the other so as not to get this short reference.
Excellent suggestion. We really need this!
