I have a workflow in N8N for sending messages to some contacts, which processes a list with generally 500 to 1000 contacts in a Loop. I am constantly having issues with this Loop, even though I have tested using Baserow as the source, Google Sheets, and more recently my own CRM system’s database (PostgreSQL).
The triggers start normally, but after a while, they begin to duplicate. Looking at the container logs, I see that the execution itself is being duplicated. In the N8N interface, only one (the first one) appears, but from the logs, we see:
2024-07-18T13:20:38.824218974Z Start job: 264636 (Workflow ID: GDfIi966az0wJT9G | Execution: 269138)
2024-07-18T13:50:25.267082467Z Start job: 264636 (Workflow ID: GDfIi966az0wJT9G | Execution: 269138)
2024-07-18T14:07:46.302098819Z Error from queue:
2024-07-18T14:07:46.302138852Z Error from queue:
2024-07-18T14:07:46.306091887Z Error: Missing lock for job 264636 failed
2024-07-18T14:07:46.306137445Z at Object.finishedErrors (/usr/local/lib/node_modules/n8n/node_modules/bull/lib/scripts.js:225:16)
2024-07-18T14:07:46.306143643Z at Job.moveToFailed (/usr/local/lib/node_modules/n8n/node_modules/bull/lib/job.js:342:19)
2024-07-18T14:07:46.306148851Z at processTicksAndRejections (node:internal/process/task_queues:95:5)
I am using N8N in queue mode, with Redis, in Docker, with separate services for editor, webhook, and worker. The worker’s concurrency is set to 40.
In a workflow that sends me error messages from executions, I receive the following message:
job stalled more than maxStalledCount
- n8n version: 1.50.1
- Database (default: SQLite): PostgreSQL
- Operating system: Ubuntu 20.4
