Edit Fields Info not continuing through Switch node
I want to check if a folder exists, if it doesn’t exist then a folder should be created in the name that the application looked for. Currently it will follow the right path, but when it comes down to creating the folder I don’t have access to any expressions.
  • n8n version: Latest
  • Running n8n via (Docker, npm, n8n cloud, desktop app): Cloud
  • Operating system: Windows
Try using the following expression:
{{ $('On form submission').item.json['Client Name'] }}
I have renamed “Edit Fields” to “parameters.”
You can use data from previously executed nodes with expressions like this: {{ $('parameters').item.json.Client }} or {{ $node['parameters'].json.Client }}
