version: '3.8'
volumes:
postgres_data:
n8n_data:
services:
postgres:
image: postgres:16
restart: unless-stopped
ports:
- 5432:5432
environment:
- POSTGRES_USER
- POSTGRES_PASSWORD
- POSTGRES_DB
- POSTGRES_NON_ROOT_USER
- POSTGRES_NON_ROOT_PASSWORD
volumes:
- ./postgres_data:/var/lib/postgresql/data
- ./init-data.sh:/docker-entrypoint-initdb.d/init-data.sh
healthcheck:
test: ['CMD-SHELL', 'pg_isready -h localhost -U ${POSTGRES_USER} -d ${POSTGRES_DB}']
interval: 5s
timeout: 5s
retries: 5
n8n:
image: docker.n8n.io/n8nio/n8n
pull_policy: always
container_name: n8n
environment:
#- N8N_HOST=${N8N_HOST}
#- N8N_PORT=5678
#- N8N_PROTOCOL=${N8N_PROTOCOL}
#- NODE_ENV=production
- WEBHOOK_URL=${WEBHOOK_TUNNEL_URL}
#- WEBHOOK_URL=https://n8n.tulipesque.com/
- GENERIC_TIMEZONE=${GENERIC_TIMEZONE}
# - N8N_PUSH_BACKEND=sse
- VUE_APP_URL_BASE_API=${VUE_APP_URL_BASE_API}
- WEBHOOK_TUNNEL_URL=${WEBHOOK_TUNNEL_URL}
- DB_TYPE=postgresdb
- DB_POSTGRESDB_HOST=postgres
- DB_POSTGRESDB_PORT=5432
- DB_POSTGRESDB_DATABASE=${POSTGRES_DB}
- DB_POSTGRESDB_USER=${POSTGRES_NON_ROOT_USER}
- DB_POSTGRESDB_PASSWORD=${POSTGRES_NON_ROOT_PASSWORD}
ports:
- 5678:5678
links:
- postgres
volumes:
- ./n8n_data:/home/node/.n8n
- ./tmp:/tmp
- ./pki:/opt/custom-certificates
depends_on:
postgres:
condition: service_healthy
It needs a file path
What you provide is a directory path
Give some examples
/tmp → directory
/tmp/test.txt → file
You should at least know what file your are looking to.
Otherwise you need other way to search the file first.
