A workflow with two persistent trigger nodes — Email Trigger (IMAP) (v2.2) and Telegram Trigger (v1.5) — activates successfully (workflow shows active: true), but the IMAP trigger never processes new incoming emails in production. The Telegram trigger in the same workflow works perfectly.
Steps to reproduce:
Workflow is active, both triggers registered.
New email is sent to the monitored IMAP mailbox.
Email remains unread in the mailbox.
No workflow execution is created (not even a failed one).
Manual “Test step” on the IMAP trigger node works fine (confirms valid credentials) — but this is only a single-node test, not the live trigger.
Already ruled out:
IMAP credentials work (confirmed by manual node test).
No workflow validation errors blocking activation.
Not an isolated case: entire workflow duplicated, copy activated — same result.
Multiple on/off toggles (UI and API) did not help.
Increased forceReconnect from default 60 to 180 minutes (mitigation from a similar community thread) — no improvement so far.
None – that’s exactly the problem. No error appears either in the interface, the execution list, or via an error workflow. The trigger simply doesn’t respond.
(Best to select only the two trigger nodes and copy with Ctrl+C, not the entire workflow – it contains business data/pricing that shouldn’t be public. Click on “IONOS Mailbox (IMAP Trigger)”, then paste into the text field.)
Not applicable – no execution takes place that could provide an output.
n8n version: 2.35.4
Database (default: SQLite): n8n Cloud (managed, not visible)
Hi @wangii Welcome!
Force Reconnect Every Minutes is the gap between reconnects, so 180 leaves the node sitting on one IMAP connection for three hours. IONOS stops pushing new-mail notices on that idle connection, the node never learns mail arrived, and nothing reaches the execution list, which is also why the Telegram trigger beside it is unaffected. Set it to 5 and switch Format from Simple to Resolved in the same node.
See this:
Hi, thanks for the explanation! Unfortunately, that didn’t get the trigger running for us again: forceReconnect has now been set to 5 minutes for about 19 hours (the format was already “Resolved”), workflow is continuously active. During this time, two new test emails arrived, both are still unread in the inbox, and not a single workflow execution was created (not even a failed one). Is there anything else we could check? Server-side logs would be helpful, if that’s possible.
That’s a useful way to get rid of them: It’s been 19 hours with forcereconnect at 5, and not a single execution has happened. So it’s not the idle connection. What’s surprising is that there are two ongoing triggers in the same workflow. Create a new workflow for the IMAP trigger and activate it. If it’s there, the problem is the combination of things rather than IMAP or the credentials, and you have your fix at the same time.
You can’t reach instance logs on n8n Cloud, that route is help@n8n.io. Send the instance URL, workflow ID and the timestamp of a test mail, and mention forceReconnect is already at 5 and Format is Resolved so you don’t get those suggestions back.
A follow-up that might clarify the diagnosis: I don’t think it’s the IMAP connection itself, but rather n8n’s own activation process. In the workflow editor, the message “Activating triggers — this can take a moment” remains permanently displayed (not just briefly), even long after the workflow is already marked as “published” according to version history and API. As long as this state persists, the “Execute workflow” button remains clickable — and a manual click on it actually processes the emails correctly. By my expectation, this button should be grayed out as soon as the workflow is truly fully active. To me, this suggests that the activation of the IMAP trigger never completes cleanly internally (gets stuck), while the Telegram trigger in the same workflow finishes immediately.
That’s a much better point, and it changes what we’re dealing with. If you see a banner that says “Activating triggers” and it won’t go away, it means that activation is stuck halfway through. This is because Telegram completes immediately, so the IMAP trigger is what’s blocking. It works with everything else: the credentials are OK, the manual runs the process, and nothing reaches the execution list because the trigger never finishes registering. It’s still worth running the single-trigger test. This is because if the banner clears with only the IMAP node in the workflow, you’ve pinned it to the two triggers that activate together.
Put that detail in the ticket verbatim, banner never clears, API says published, Execute workflow stays clickable, manual runs work. That’s far more actionable than “the trigger doesn’t fire” and it’s something they can match against activation logs on their side.
Thanks for the suggestion! I tested exactly that: created a separate, minimal workflow with ONLY the IMAP trigger (same IONOS credentials, nothing else, no Telegram trigger alongside it) and activated it.
Result: same problem. A test email was sent, still sits unread in the mailbox, 0 executions. So it’s not due to the combination of multiple triggers in the same workflow – the IMAP trigger fails completely even in isolation on its own.
The single-trigger result rules out the last thing left on your side, and this is now tagged as a confirmed bug, so no setting will bring the trigger back.
Until the fix ships, take the mailbox off the persistent IMAP connection. Add a forwarding rule on the IONOS mailbox to a Gmail address and use the Gmail Trigger with Poll Times set to every minute. It fetches on a schedule instead of holding an IDLE session open, and a poll that finds nothing does not count against your execution quota.
