Empty Output Flow
my node executes successfully but returns no items, causing downstream nodes to process nothing, what can I do
**This isn’t a failure **
it’s a silent logic break.
Add validation before passing data forward. Use an IF node to check item count ({{$items().length}} > 0) and branch accordingly.
Also inspect upstream nodes to confirm data is actually being emitted, not filtered out unintentionally.
One thing — make sure youre checking WHERE the empty output comes from, not just that its empty. is it the source node returning nothing, or a filter removing items? use the debug output at each step. also “always output data” on filter nodes has fixed it for us
