The idea is:
Set the toggle button to set Prompt Caching for each models.
My use case:
I use llm models in AI agent node , using system prompts I would like to save my token.
The prompt that called has so long and always same prefix for sytem prompt.
Gemini model has both implicit chaching and explicit caching , I hope explicitly set the chaching.
Claude also has a parameter to set the prompt chaching.
Not the advanced level but I could work with for testing or something.
