Enhancing Retry Behavior for 'Stop and Error' Node
In my opinion, when an error is triggered by the “Stop and Error” node, the retry option (from the last executed node) should instead retry the execution from the node before the Error node. This is because using the “Stop and Error” node soft-locks the execution retries and forces you to copy the trigger node’s JSON and execute it from the start—which, by the way, would also be a nice feature to add.
