Is anybody currently working on an Enterprise AI builder workflow?
Interesting question, it really depends on what exactly you mean by “Builder”.
Here’s how I do it: I mainly work in Claude Code and have the process build there.
The reason is that I want to refine the requirements and review the implementation plan before anything even lands in n8n.
Deployment and initial testing work really well via MCP.
What usually still needs to be done manually after that: entering credentials and logging in to verify the connection, for example with Google or Microsoft.
What’s your specific use case and what should it look like that you want to automate?
Welcome to the n8n community @JesusFreakFox
Could you please elaborate more on the context of your question?
Even AI can’t understand it hehe
