Error 503 or lost connection
Hey everyone! I am having a error with n8n, every time I enter to n8n 10 seconds later i lost connection, when it comes back I run a workflow but same problem or error 503. Does someone know what is happening???
Im just paying for nothing… Sorry, my english is rusty
Hey @Duck_Tech !
Did you tried to restart your instance, and check maybe that your workflow loops is not crashing it.
Connect to your Admin Panel, and restart workspace, if this is not working, your workflow is doing that.
Cheers!
I am facing the exact same issue. Did anything work?
Hi
I checked your instance and saw some OOM occurrences around that time, its looking stable at the moment. I would recommend that you engage the support team ([email protected]) if you continue to see this issue as support are best placed to review and advise.
Additionally, we offer some guidance in our docs on how to reduce memory utilisation in workflows here:
Hi @Anishi_Shah
If you are on n8n cloud and see this, please reach out to support ([email protected])
