Error in Searching Contacts using Hubspot integration when using Expression filter
I am trying to search for a Contact in Hubspot using the Hubspot node. I am getting this error.
ERROR: UNKNOWN ERROR - check the detailed error for more information
Invalid input JSON on line 1, column 134: operator EQ requires a value
This only happens when the Filter value is set as an Expression. If it is set to Fixedm it works. Not sure what am I doing wrongly.
Please share the workflow
(Select the nodes and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow respectively)
  • **Running n8n via cloud
Hi @melvinomh, welcome to the community :tada:
I am sorry you’re having trouble. This error is coming from Hubspot and suggests a missing value. Is there a chance not all the items you are passing on to your Hubspot node have an Email Address field?
Hi @MutedJam , I was able to resolve this buy just using a custom HTTP Request to Hubspot. Thanks.
