**Error: "input.split is not a function (item 0)" in N8N Gmail Node**
Issue: Error: “input.split is not a function (item 0)” in N8N Gmail Node
I’m encountering an error when using N8N’s Gmail node to send an email. The error message is:
Context:
  • Node: Gmail node (operation: send email)
  • Source: Data is being pulled from a previous node (a database) via the “response” field.
  • Error Trigger: The workflow runs fine, but when it gets to the Gmail node, I receive the split error.
  • What I’m Using:
    • I’m dynamically passing to, subject, and message fields to the Gmail node using expressions like {{$json.message.content.to}} and others for subject and message.
    • I have the “Specify Input Schema” option enabled in the email node.
Troubleshooting So Far:
  • The error seems to indicate that the Gmail node is trying to split a value that isn’t a string (likely undefined or null).
  • I’ve verified that some fields, like bccList, are undefined, but they’ve been empty in the past without causing issues.
  • I attempted hardcoding the to, subject, and message fields with static strings, and the email sends successfully, so the issue seems to lie in how the dynamic data is being passed.
What I’ve Tried:
  • Adding fallback values to the fields (e.g., {{$json.message.content.to || '[email protected]'}}) to ensure nothing is undefined.
  • Debugging the “response” field, but it seems to contain the expected data structure.
Questions:
  1. Is this error related to how N8N handles undefined or empty values in specific fields?
  2. Could the “Specify Input Schema” setting be causing the issue? How should I properly configure it for email nodes?
  3. Any other troubleshooting tips for preventing this “split” error when passing dynamic data to the Gmail node?
Thanks for your help!
The gmail node: {
“meta”: {
“instanceId”: “36b7251c6ad6e7f498073af8dcd52f607ff829cf47cd1af3ce3282d097429edb”
“nodes”: [
“parameters”: {
“sendTo”: “={{ $json.message.content.to }}”,
“subject”: “={{ $json.message.content.subject }}”,
“emailType”: “text”,
“message”: “={{ $json.message.content.message }}”,
“options”: {
“appendAttribution”: false,
“bccList”: “={{ $json.message.content.bccList || }}”,
“ccList”: “={{ $json.message.content.ccList || }}”,
“senderName”: “=James, David’s AI Bot”
“id”: “1dccc81d-ab72-4b57-b82a-b0a51c8d25b1”,
“name”: “Gmail”,
“type”: “n8n-nodes-base.gmail”,
“typeVersion”: 2.1,
“position”: [
1340,
620
“credentials”: {
“gmailOAuth2”: {
“id”: “we19m4AKI8reQ2PL”,
“name”: “Gmail account”
“connections”: {},
“pinData”: {}
Following up with the details on this:
From Gmail
Full message
Other info
Item Index
0
Node type
Node version
2.1 (Latest)
n8n version
1.55.3 (Cloud)
Time
9/14/2024, 3:15:22 PM
Stack trace
NodeOperationError: input.split is not a function (item 0) at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Google/Gmail/v2/GmailV2.node.js:549:23) at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:728:42) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:673:66 at processTicksAndRejections (node:internal/process/task_queues:95:5) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1104:20
Gmail
Parameters
Settings
Docs
Credential to connect with
Resource
Operation
To
Fixed
Expression
[email protected]
Subject
Fixed
Expression
Erinnerung: Bitte sende mir den Link zum Hochladen der Dokumente
Email Type
Message
Fixed
Expression
Liebe Maria Elisabeth, ich hoffe, es geht dir gut. Ich möchte XXX. Vielen Dank für deine Unterstützung. Mit freundlichen Grüßen, David
Options
Append n8n Attribution
Fixed
Expression
BCC
Fixed
Expression
[Array: ]
CC
Fixed
Expression
[Array: [“[email protected]”]]
Sender Name
Fixed
Expression
I wish this node would…
i wish it too
