I am geting a generic error every time I use a specific tool agent. It seems that the error is caused by an input on a specific tool, but I have already tried changing and better defining the input. The weird thing is that the error happens on random times and not in all executions.
“errorMessage”: “Internal error”,
“errorDetails”: {},
“n8nDetails”: {
“n8nVersion”: “1.53.2 (Cloud)”,
“stackTrace”: [
“Error: Received tool input did not match expected schema”,
" at DynamicStructuredTool.call (/usr/local/lib/node_modules/n8n/node_modules/@langchain/core/dist/tools/index.cjs:88:19)“,
" at processTicksAndRejections (node:internal/process/task_queues:95:5)”,
" at /usr/local/lib/node_modules/n8n/node_modules/langchain/dist/agents/executor.cjs:479:27",
" at async Promise.all (index 0)“,
" at AgentExecutor._call (/usr/local/lib/node_modules/n8n/node_modules/langchain/dist/agents/executor.cjs:471:30)”,
" at AgentExecutor.invoke (/usr/local/lib/node_modules/n8n/node_modules/langchain/dist/chains/base.cjs:58:28)“,
" at Object.toolsAgentExecute (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/dist/nodes/agents/Agent/agents/ToolsAgent/execute.js:144:30)”,
" at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/dist/nodes/agents/Agent/Agent.node.js:349:20)“,
" at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:728:19)”,
" at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:673:51",
" at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1086:20"
- n8n version: 1.53.2
- **Running n8n via n8n cloud
- Operating system: windows
