- n8n version: 1.39.0
- Database (default: SQLite): Postgres
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Operating system: Ubuntu 22
Hello everyone,
I’ve been running into an issue with custom entities after incorporating the recent changes to the n8n-custom Dockerfile (commit: refactor(core): Rebuild docker infrastructure (#8451) · n8n-io/n8n@1db35c1 · GitHub).
Our setup:
- Using n8n for the past 3 years
- Added three custom tables to the database (PostgreSQL) using migrations
- Added corresponding entities and repositories in the
packages/cli/databases
folder - Everything worked fine until the mentioned Dockerfile changes
Now, we’re encountering the following error:
No metadata for "EventTriggerEventEntity" was found.
I’ve logged the following variables before instantiating our custom entity:
const con = Container.get(Connection);
console.log(con.entityMetadatasMap);
console.log(con.getMetadata('EventTriggerEventEntity'));
Both logs show our custom entity metadata as expected. We can also instantiate n8n core entities like WorkflowEntity
without any issues.
Has anyone else faced a similar problem after the Dockerfile changes? Or does anyone have a solution for this issue with custom entities?
Any help or guidance would be greatly appreciated!
