Error on Connecting with LinkedIn
I’ve tried disabling the organisation support too, but I still get the same error - Error fetching options from LinkedIn
I’m currently running this on my desktop/ n8n website.
May I know how do I go about resolving this, cause it has been days :frowning: and I couldn’t find a solution to this still
Hey @rebbitkar,
Can you disable organization Support and enable Legacy then connect your credential and see if that works.
ive tried that as well but still the same error
Hey @rebbitkar,
Whihc version of n8n are you using? It looks like Cloud but if you go to help > about what version is displayed?
this is what i see
