Error on Telegram Trigger when sending audio
Hi,
I am trying to send an mp3 audio with “Send Audio” operation but I get next error:
I assume “additionalFields” is not defined in Telegram Node when “Send Audio” operation is defined.
Is it possible to check it?
Thanks
Thanks! Will have a look.
Yes there was an error. It should display the “Additional Fields” also for “Send Audio”.
Got fixed:
and will be released with the next version.
Thanks for making us aware of it. Guess not many people used that option until now :wink:
Got released with [email protected]
Hi Jan,
I have checked and I get next error:
ERROR: Could not get parameter “replyMarkup”!
Parameter is missing :frowning:
That is confusing. Have to have a look at that later.
Ok got fixed. Also added bot:info to easily get the chat _id and user_id as they were a pain to find.
Ok we released now [email protected] . That version should now work properly.
Checked and works like a charm :slight_smile:
We have published a workflow that generates a custom audio speech and sends to a Telegram node. You can find the workflow at
