I want to read one or several output data from one previous node not connected directly with my current node.
ERROR: The node “Function2” is not connected with node “Recover Last Modification” so no data can get returned from it. [Line 1]
ExpressionError: The node "Function2" is not connected with node "Recover Last Modification" so no data can get returned from it.
at WorkflowDataProxy.getNodeExecutionData (/private/var/folders/5b/0z88mwfd2339srrjkk1j8p7r0000gn/T/AppTranslocation/B9B6E4BE-05C0-496E-83B6-460E27BD873E/d/n8n.app/Contents/Resources/app/node_modules/n8n-workflow/dist/src/WorkflowDataProxy.js:163:27)
at Object.get (/private/var/folders/5b/0z88mwfd2339srrjkk1j8p7r0000gn/T/AppTranslocation/B9B6E4BE-05C0-496E-83B6-460E27BD873E/d/n8n.app/Contents/Resources/app/node_modules/n8n-workflow/dist/src/WorkflowDataProxy.js:196:48)
at get (<anonymous>)
at BaseHandler.get (/private/var/folders/5b/0z88mwfd2339srrjkk1j8p7r0000gn/T/AppTranslocation/B9B6E4BE-05C0-496E-83B6-460E27BD873E/d/n8n.app/Contents/Resources/app/node_modules/vm2/lib/bridge.js:441:11)
at /private/var/folders/5b/0z88mwfd2339srrjkk1j8p7r0000gn/T/AppTranslocation/B9B6E4BE-05C0-496E-83B6-460E27BD873E/d/n8n.app/Contents/Resources/app/node_modules/n8n-nodes-base/dist/nodes/Function:1:149
at /private/var/folders/5b/0z88mwfd2339srrjkk1j8p7r0000gn/T/AppTranslocation/B9B6E4BE-05C0-496E-83B6-460E27BD873E/d/n8n.app/Contents/Resources/app/node_modules/n8n-nodes-base/dist/nodes/Function:8:2
at BaseHandler.apply (/private/var/folders/5b/0z88mwfd2339srrjkk1j8p7r0000gn/T/AppTranslocation/B9B6E4BE-05C0-496E-83B6-460E27BD873E/d/n8n.app/Contents/Resources/app/node_modules/vm2/lib/bridge.js:479:11)
at NodeVM.run (/private/var/folders/5b/0z88mwfd2339srrjkk1j8p7r0000gn/T/AppTranslocation/B9B6E4BE-05C0-496E-83B6-460E27BD873E/d/n8n.app/Contents/Resources/app/node_modules/vm2/lib/nodevm.js:425:23)
at Object.execute (/private/var/folders/5b/0z88mwfd2339srrjkk1j8p7r0000gn/T/AppTranslocation/B9B6E4BE-05C0-496E-83B6-460E27BD873E/d/n8n.app/Contents/Resources/app/node_modules/n8n-nodes-base/dist/nodes/Function/Function.node.js:96:31)
at Workflow.runNode (/private/var/folders/5b/0z88mwfd2339srrjkk1j8p7r0000gn/T/AppTranslocation/B9B6E4BE-05C0-496E-83B6-460E27BD873E/d/n8n.app/Contents/Resources/app/node_modules/n8n-workflow/dist/src/Workflow.js:594:51)
at /private/var/folders/5b/0z88mwfd2339srrjkk1j8p7r0000gn/T/AppTranslocation/B9B6E4BE-05C0-496E-83B6-460E27BD873E/d/n8n.app/Contents/Resources/app/node_modules/n8n-core/dist/src/WorkflowExecute.js:537:64
Please share the workflow
I want that the output info from the last node will be the same as “Recover Last Modification” node
- n8n version: 0.182.0
- Database you’re using (default: SQLite): N/A
- Running n8n with the execution process [own(default), main]: own
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: desktop app
