Here are the nodes with the mock up data:
"nodes": [
"parameters": {
"authentication": "headerAuth",
"requestMethod": "POST",
"url": "={{$node[\"Set tokens\"].json[\"server\"]}}dtable-server/api/v1/dtables/{{$node[\"Set tokens\"].json[\"id\"]}}/rows/",
"jsonParameters": true,
"options": {},
"bodyParametersJson": "={\n\t\"row\": {\n\t\t\"id\": \"{{$node[\"New member\"].json[\"body\"][\"id\"]}}\",\n\t\t\"full_name\": {{JSON.stringify($node[\"New member\"].json[\"body\"][\"profile\"][\"nombre-completo\"])}},\n\t\t\"email\": {{JSON.stringify($node[\"New member\"].json[\"body\"][\"email\"])}},\n\t\t\"mobile\": {{$node[\"New member\"].json[\"body\"][\"profile\"][\"celular\"]}},\n\t\t\"membership_id\": \"{{$node[\"New member\"].json[\"body\"][\"membership\"][\"id\"]}}\",\n\t\t\"membership_status\": \"{{$node[\"New member\"].json[\"body\"][\"membership\"][\"status\"]}}\",\n\t\t\"role_id\": \"{{$node[\"New member\"].json[\"body\"][\"profile\"][\"rol\"]}}\",\n\t\t\"subscription_id\": \"{{$node[\"New member\"].json[\"body\"][\"membership\"][\"subscribed_to\"]}}\",\n\t\t\"hubspot_id\": \"{{$node[\"New member\"].json[\"body\"][\"profile\"][\"huid\"]}}\",\n\t\t\"mixpanel_id\": \"{{$node[\"New member\"].json[\"body\"][\"profile\"][\"mpid\"]}}\",\n\t\t\"terms_agreement\": {{$node[\"New member\"].json[\"body\"][\"profile\"][\"terms\"]}},\n\t\t\"marketing_authorization\": {{$node[\"New member\"].json[\"body\"][\"profile\"][\"promo\"]}}\n\t},\n\t\"table_name\": \"users\"\n}"
"name": "Create new user",
"typeVersion": 1,
"position": [
830,
350
"notesInFlow": true,
"retryOnFail": true,
"waitBetweenTries": 300,
"credentials": {
"httpHeaderAuth": "Main DB Base Token (R/W)"
"notes": "Seatable"
"parameters": {
"filePath": "/root/data/tokens.json"
"name": "Get tokens",
"type": "n8n-nodes-base.readBinaryFile",
"typeVersion": 1,
"position": [
480,
350
"parameters": {
"options": {}
"name": "Set tokens",
"type": "n8n-nodes-base.moveBinaryData",
"typeVersion": 1,
"position": [
670,
350
"parameters": {
"functionCode": "return [\n { \n json:\n{\n\"headers\": {\n\"x-real-ip\": \"184.72.168.109\",\n\"x-forwarded-for\": \"184.72.168.109\",\n\"host\": \"instantvoices.hooks.n8n.cloud\",\n\"x-forwarded-proto\": \"https\",\n\"x-nginx-proxy\": \"true\",\n\"connection\": \"close\",\n\"content-length\": \"610\",\n\"accept\": \"application/json\",\n\"content-type\": \"application/json\"\n},\n\"params\": {\n},\n\"query\": {\n},\n\"body\": {\n\"id\": \"610c4361e6e830000410a135\",\n\"email\": \"[email protected]\",\n\"profile\": {\n\"nombre-completo\": \"Agustin Albornoz\",\n\"celular\": \"1159244084\",\n\"huid\": \"38476cd9a02f9d7a28471733c024e20b\",\n\"mpid\": \"17b17e6889329a-071ac809f69307-4343363-e1000-17b17e68894803\",\n\"pageuri\": \"www.instantvoices.com/cuenta/registro-locutor\",\n\"pagename\": \"Registro locutor\",\n\"terms\": true,\n\"promo\": false,\n\"rol\": \"rol-0002\",\n\"ip\": \"200.126.195.33\",\n\"id\": \"610c4361e6e830000410a135\"\n},\n\"membership\": {\n\"id\": \"610c4361e6e830000410a136\",\n\"subscribed_to\": \"60e7ab9bdd79d800047d24d0\",\n\"status\": \"active\",\n\"type\": \"free\",\n\"test_mode\": true\n},\n\"created_at\": \"2021-08-05T20:00:33.000Z\"\n}\n}\n}\n]"
"name": "New member",
"typeVersion": 1,
"position": [
310,
350
"connections": {
"Get tokens": {
"main": [
"node": "Set tokens",
"type": "main",
"index": 0
"Set tokens": {
"main": [
"node": "Create new user",
"type": "main",
"index": 0
"New member": {
"main": [
"node": "Get tokens",
"type": "main",
"index": 0
If I use expression the node gives me the invalid JSON error, if I paste the resolved data, it continues without a problem.
