Error: The Tool attempted to return an engine request, which is not supported in Agents
Workflow:
When it reaches the sub-agents they never activate the tools.
Version: Version 2.6.4 (Self-Hosted)
Hi @Bruno_Dalla_Costa Welcome to the community the problem almost always is linked to the system and instructions you have provided , i mean the AI prompt and System prompt, when we use Sub AI Agent nodes we have to clearly define the sub AI Agent as a tool in the description and also in main agent in the AI prompt and the system prompt you have to explicitly mention how to use that and how that would work!
the description field on the sub-agent tool is what the parent agent uses to decide when and how to call it. if it’s vague, the parent skips it.
make the description extremely explicit — something like “call this tool when the user asks about contracts. it returns X format.” also add in the parent’s system prompt: “you MUST call [tool name] for [specific trigger]”. that usually fixes it.
