Error using Azure OpenAI And OpenAI LLM
UPDATE: Same error after awaping to OpenAI (not Azure OpenAI)
I’m getting proper response, but still it reports error.
Any idea why???
ERROR:
No prompt specified
Expected to find the prompt in an input field called ‘chatInput’ (this is what the chat trigger node outputs). To use something else, change the ‘Prompt’ parameter
Well… I found bypass, but it is very stupid bypass… I added “Edit Field” node, and set output to chatinput, pass it to the agent, and change the source to chat…
I’m sure I hit a defect.
Please let me know if I missed something and it should have done differentlly.
Also got the same error. No clue why. Makes no sense.
My OpenAI (message assistant) is directly connected to the chat trigger.
