When I’m using the Gmail node on my N8N server using Docker ( Version 0.193.3), I have the following error :
ERROR: Found non-callable @@iterator
TypeError: Found non-callable @@iterator
at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Google/Gmail/Gmail.node.js:570:28)
at processTicksAndRejections (node:internal/process/task_queues:96:5)
at async Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/src/Workflow.js:598:28)
at async /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/src/WorkflowExecute.js:557:53
